Need Help with "Cue" settings Topic is solved
Samromo2
When I click on a "cue" all my sequences start playing at the same time. How can I change it so that when I click on a "cue" my sequences do not start playing automatically. I want to manually click on them. Any help would be greatly appreciated. Thank you. Sam
- Spirit
- FreeStyler Version: 3.5.9
Re: Need Help with "Cue" settings
one the cue window you see two "COG wheels"
one shown on the image you uploaded and a other one more located at the cuelist buttons.
if you press the one above the cuelist buttons and press on "Load cuelist only"
this will solve your problen now only the cuelist will be loaded without setting it all on PLAY
Samromo2
Thank you very much for your help. I am not sure why, but I am not seeing "Load cuelist only"
I have attached a screen shot of the options the "cog" wheel shows me
- Spirit
this means you run version 3.3.2 or something.
if you download the latest version you can acces the new feature..
