New ADJ Spot LED Profile
burner
Post by burner »
I created this profile for the Spot LED. It is not perfect but it works. This was my first attempt at a profile.
Re: New ADJ Spot LED Profile
Post by Jan_K »
Hej burner
Looks nice.
Please use "Export" in Fixture creator and upload the "pff" file.
The pff file contains all images and icons for the fixture.
And a small tip.
You can use macro to place channel 5 in the dedicated ranges.
Gobo change, Color Change, Gobo color change and shake.
You can then use "Show in" to place them in the Gobo panel.
http://www.freestylersupport.com/wiki/f ... figuration
burner
Post by burner »
/Jan,
Thank you for the helpful info.
burner
Post by burner »
Here is the revised .pff file for the spot LED. It includes the gobo and color rotations in the macro section as per Jan_K suggestion.
burner
Post by burner »
Here is the revised .pff file for the spot led.
DJ Spot LED.pff
Updated as per Jan_K suggestions.
(118.93 KiB) Downloaded 48 times
Post by Jan_K »
Think you attached the wrong file.
There are no macros :D
burner
Post by burner »
Actually there are no macros. Also, gobo shake is really the only added
benefit from using the macro creator. Rotation and color change
fast and slow can be controlled in their respective windows via the sliders
and using the multi color icon.
:D
Merry Browen
Post by Merry Browen »
led light bulbs
led lighting downlights
LED Fluorescent Replacement
fanatico503
Post by fanatico503 »
i cant get my lamp to turn on for my djspot l.e.d.. can someone please help thanks
Return to “American DJ”
