I mentioned in another thread that I had some problems with submasters on my LED bars, and first I thought that it was a simple "forgot the intensity" problem, sadly, that wasnt the case...
The problem is as follows: When I use submasters, I dont get any output to my LED bars or my LED par cans. The indicator on each fixture on the screen shows the correct color and intensity, the intensity slider on the submasters are at 100%, but the light dont turn on.. I can see in the Show Output window that Freestyler dosent send anything on the relevant channels..
I programmed the scenes with only the correct channels active, I test them first when I make them in online mode, then the work perfectly,then I load them into the Cue, and start them there, still works perfectly, I save a Cue, say for only Red for the ledbars, no other channels are programmed, only Red channel is set to Fade, programmer is in Transparent mode (I´ll doublecheck that, but 99,999% sure)
And when I load the Cues I´ve made in to a submaster, and start it, I simply dont get any output.. I can see that the sequences are running, both in the submaster and in the Cue window, and the correct thing is happening on the screen...
The only channels that are programmed are colorchannels for the ledbars and Intensity for the par cans.
But my submasters work for my scanners, and I think, for my lasers, both Intensity channels and other.
If I have a cue for the ledbars loaded in a submaster, other sequences for the ledbars doenst work if I try to start them from the cue. And I belive that the same thing happens even if I have say cues for the scanners loaded in submasters, and the submaster window open, and try to start a ledbar sequence loaded directly to the cuelist.
This feels very strange to me, it should not work this way I guess?
I tried it at a show I did this friday, all my sequences were made for submaster use, but I had to run with just the Cuelist.. not very practical
Also, I made sure that the ledbars and parcans were in the correct mode, and that the relevant channels werent in any override mode. and well, it worked when I made the sequences, and as soon as I gave up SM´s and closed that window, it worked fine, without any other changes..
Please, can someone help me get this sorted? I´d really like to be able to use the SM´s, feels so much more flexible! Even more so I think when running many and many different lights at the same time, live.
btw, I´m running the latest stable version of Freestyler, on a Win 7 computer.
