Hello
We have bought new LED lighting and i need to modify lamp control window to move light from 0-155 instead od 155-255. Correction of channel doesn`t allow u to set up more then - 99 so what`s a solution for that problem? And moving manually from fades window will not work for me bcs we use them as strobo sometimes.( it is from 155-255). Unlocking/locking channels is a pain in back:P.
LED par 64 LAMP more then 99 correction
nevercalled
nevercalled
Re: LED par 64 LAMP more then 99 correction
On second tough i didn`t find a way to lock it up to 155 even.
Correction of 155 is exactly what i need and sometimes i can change correction manually.
- Hambone
- Band Member
- FreeStyler Version: Beta
- I Use FreeStyler for: Band
Your best bet would be to create a new fixture in the Fixture Creator (or edit your existing one). In there, you can set the minimum and maximum values for your intensity/dimmer channel, and also define the strobe channel and values for slow/medium/fast.
http://two-for-flinching.com
I have put it into the bug tracker.
