I have 6x Stairville led par56s which work fine, i bought another 6 to add to them and im having problems with them.
I have noticed that the older ones which work only have 8 dip switches, the new ones have 12, and on Thomann they are priced differently, what differences are there in these lights and is there another fixture profile i can use??
I think the new ones might be 6 or 7 channel but cant be sure!
Stairville led par56 profile problem
Fabio74
Re: Stairville led par56 profile problem
I'm in the same situation.
Were you able to solve?
thanks
Fabio
thanks
Fabio
