Chuavet MotionDrape and MotionFacade
DJChris8805
Give these a try, they work for me.
MotionFacade.pff- (111.03 KiB) Downloaded 87 times
MotionDrape.pff- (132.64 KiB) Downloaded 100 times
DjDapperDan
Re: Chuavet MotionDrape and MotionFacade
Hello DJ Chris, these both gave errors when I tried to use them? do you have FXT files?
- FreeStyler Version: Beta
Try these ones.
JickMagger
Hey, I got a question.
Is there a way to put Motion Drape into automatic mode using Freestyler?
Or I can do it only using manual mode, not DMX?
Hej JickMagger
I had a look in the manual and it looks like the automatic mode only is accessible via the "menu" meaning there are no DMX command for this.
So you can only do it manually.
JickMagger
Hey Jan,
thanks for your reply. I had the same impression but my idea was put few commands that exist in the manual in some kind of chain, a sequence. Which should be possible. You know - couple of commands that will change one to another from time to time by itself. Do have an idea how to do it?
Or maybe it's just freestyler that doesn't give this kind of option and I should use different software?
JickMagger
Hey Jan,
- Spirit
- FreeStyler Version: 3.5.9
hi
on Channel 6 and 7 you can choose between Pre-made programs.
and on channel 8 you can change the speed.
so you can create a sequence that changes value on Channel 6 or 7 and there by change the Pre-made programs.
and if none of this works, dont search more as all lighting software/desk send a "DMX" (RS485) signal and its all the same.
liveforareason
Are the above .pff files the best files for using a Chauvet MotionDrape?
Psicotropical
- FreeStyler Version: 3.3
thanks ;-]
