Fixture help - 400w UV Cannon
neils
Post by neils »
Wasnt sure if I should post here or the fixture request section, so posting in both, and hopefully someone will notice. I have one of those monsterous 400w UV Cannons. I want to add this to FS as well as 3D, so need to create 2 fixture profiles. The channel would actually control a DMX switch pack, to turn on the cannon. Would prefer to have a picture of the cannon, instead of using the Shadow LED panel that is included with FS. Also need this thing to blast out a big wide angle of purplish light in 3D, any way of doing that
Neil
BillsGate
FreeStyler Version: 4.x
Re: Fixture help - 400w UV Cannon
Post by BillsGate »
The freestyler part of the fixture creation is actually not that hard. Have you tried that already?
The Wiki has a nice and well explained section on the Fixture Creator:
http://www.freestylersupport.com/wiki/f ... ns_dimmers
neils
Post by neils »
I know how to create a fixture, both in FS as well as 3D. The issue is that I would like to define a larger size fixture, and one that is capable of projecting a wide angle wash of purple UV. Right now, I simply started with a PAR fixture, but no matter what beam angle I chose (maxed out at 110 degrees in this case), it sill shows up with a narrow PAR64 beam. I was able to force the purple color thru on the 3D side, but that is about it. I guess worst case, it does the job, and tells me when the light is on. I just need to find out how to get the beam wider now, just like its done on a Martin Atomic strobe.
