Kam Par Bar Mk III [SOLVED] Topic is solved
fishmongery
Post by fishmongery »
Hi there,
I'm new to DMX but I have managed to get my ADJ Comscans and my ADJ Tri Par Profiles working with Freestyler. The Fixture Creation is still a bit lost on me and I tried an existing file for the Kam Par Bar which I found on here but nothing is happening.
Can anyone suggest what I am doing wrong and if there is a file for the Par Bar Mk III.
Adam
Re: Kam Par Bar Mk III
Post by Jan_K »
If abesoutely nothing happens then it is most likely an addressing issue.
Be sure that the address is correct and if there are a mode then also check that thw mode is set correct.
Also note you can use the slider panel in right side of FreeStyler to direct control the fixture.
With a user manual and the sliders then you should be able to turn on light.
Post by Jan_K »
KAM_Par_Bar_MKIII.pff
(20.29 KiB) Downloaded 124 times
fishmongery
Ok that's great thanks
fishmongery
Jan you are a star! Working perfectly now, nice one!!
fender_jazz_72
Post by fender_jazz_72 »
Just downloaded this myself & now my bar is working too, thanks :)
alexclarke
Re: Kam Par Bar Mk III [SOLVED]
Post by alexclarke »
Is this similar to the Kam Partybar? I could do with a fixture for that and the Kam LED Par 56, cheers
