Stage Ape Hampster LED PAR 38 Can Topic is solved
thelodgemd
Post by thelodgemd »
Does anyone have a fixture profile for this light? I'm a small club owner with limited knowledge and can't get one out of FC that works. Thanks for your help! DMX specs here: http://www.stageape.com/pages/hampster.html
thelodgemd
Re: Stage Ape Hampster - My Partial Fixture that I tried
Attached is my fixture that I tried to create for the Stage Ape Hampster...THANKS FOR ANY HELP/GUIDANCE!
Light specs = DMX mode:
The HAMPSTER is a 7 channel dmx light so you start DMX value 1. Set dip switches #1 & # 10 on the first fixture to the on position. Dip switch 10 is on to tell the light it is in DMX mode and does not have a value.
Slider #1 controls the green LED's
Slider #2 controls the red LED's
Slider #3 controls the blue LED's
Slider #4 0-16 white (red, blue and green LED's on)
17-31- red
32-47- purple
48-63- blue
64-79- aqua
80-95- green
96-120- light green
121-255- color change (set speed of color change with slider #5)
Slider #5 0-255 slow to fast color change (when slider #4 is set to 121-255)
Slider #6 0-127- strobe (from slow to fast)
128- 131- solid on
132-191- strobe fade in (fades from zero to full brightness)
192-240- fade (lights up and fades out)
241-255- solid on
Slider #7 Dimmer (slider must be all the way up for the functions to work)
On the first fixture set dip switch #1 and #10 to the ON position. For easy use with our ACROBAT, set the second fixtures dip switch #1 and #5 and dip #10 to the ON position and that will give you control of the light using the #2 fixture/scanner button on the DMX controller. To run the lights all at once just set all the lights dip switches to #1 and #10 to the ON position.
Hampster0311.pff
(2.48 KiB) Downloaded 89 times
Re: Stage Ape Hampster LED PAR 38 Can
Post by Jan_K »
Hej thelodgemd.
Think you have an error some where.
You have RGB on 2,3 and 4 in the fixture.
In the list R is 2, G is 1 and B is 3.
Also I think the shutter channel should be left empty.
thelodgemd
Thank you!
Post by Jan_K »
When you have modified this then upload it again and I will have a look.
Do you have the fixture so you can test it.
See eventually http://www.freestylersupport.com/wiki/f ... led_parcan
thelodgemd
Hello, Jan...I have made progress on this fixture. Please see attached. I don't understand how to address the color change option...Slider 4. Any help and guidance is appreciated. I tried to address color change through the macros - as you will see. Best, Ryan
17-31- red
32-47- purple
48-63- blue
64-79- aqua
80-95- green
96-120- light green
128- 131- solid on
241-255- solid on
Hampster.pff
(3.72 KiB) Downloaded 76 times
Post by Jan_K »
I just had a fast look on the fixture.
The strobe has 3 effects strob, fade in and fade out.
I have changed the values so the strobe is on the strobe fader and the fade in / out are on macros.
Also I am not sure why you have used lamp on function.
I have moved the speed to a gobo channel so there are a fader linked to this function.
The rainbow and the fade in out may have a speed control depending on the what value in the range that are used.
That you have to detect and eventually change.
Have a look and try it.
Hampster 1_0.pff
(23.22 KiB) Downloaded 130 times
