American DJ Jelly Fish
iAmDJomega
- FreeStyler Version: 3.4.8
- Twitter: www.twitter.com/iAmDJomega
Hey guys I'm new to this. I was wondering if anyone had ADJ Jelly Fish lights files? Thanks for the help!
aspen20
Re: American DJ Jelly Fish
- FreeStyler Version: Beta
Hej aspen20
Do you know if the color pattern for the jelly fish and the revo sweep are the same.
aspen20
Howdy,
I believe the color light patterns are the same. I don't have a Revo Sweep to compare to the Jelly Fish. However, after looking at a few reviews on youtube. they look the same to me.
Just an other question.
There are 7 lenses.
I assume that the dots in your icons indicates the color for each lens but in you icons there are only 6 dots.
There are 7 lenses.
Just a quick comment.
If you uses the icon size 30x30 then you will have a nice lint-up of icons.
Also try to have the fixture image 60x60.
http://www.freestylersupport.com/wiki/f ... _and_icons
Have you noted that there are 25 chases not 24
My plot is from the revo sweep.
(I can't load it, because it is from a Fixture Creator Beta that will not work together with the FC that you use)
