New version install procedure? Topic is solved
skintner
Post by skintner »
I have downloaded the new version of FreeStyler but have found no installation directions in terms of uprading. Can I install the new version OVER the previous version or must I remove (uninstall) the previous version first? I suppose I will lose my fixtures and setup?
thanks
steve
Re: New version install procedure?
Post by Jan_K »
Hej Steve
I normally don't unstall the old version.
There is a check box where you can select if you want to over write the old fixtures.
It is default off so your existing fixtures will be untouched.
