Hi Everybody,
We're buying more and more LED stuff, which is really chanel-intensive. The other problem is, that we often have long dinstances between FOH and Stage. So we thought about buying a Elation E-Node 8. Theoretically we can use 8 Universes. Infact we don't need 8 universes, but 2 would be great. Is this also realized in the Beta, you talked about in the other Post? I would really apreciate if there would be a possibility to test this!
Thanks a lot in advance if there would be a way to realise this!
Greetings from germany
Dosi
Multi Universes via ArtNet
