Run Par Can Stage Topic is solved
dwebb1911
Run Par Can Stage
I want to use Freestyler to run my stage lights. We provide sound & light mainly for festivals. Generally an all day event will have multiple bands sharing the stage. Currently we have 8 Par 56 on the down stage truss and 8 LED Par 64 on the up stage truss. Also have an additional 4 64’s on the down stage used for blinders. I would like to be able to use Freestyler in the following way: I would like to create scenes that I can turn on and off via the buttons i.e. Blue Stage, Purple Stage, Full on Colors stage etc… I can’t seem to figure out how to do this. I want to set the colors I need for each fixture, save that all as a scene and use buttons to turn on / off . Thanks
- Spirit
- FreeStyler Version: 3.5.9
Re: Run Par Can Stage
if you create a Scene with One step and put it on the OVERRIDE BUTTONS.
it willl work as a ON/OFF button or you can also enable Flash so you can Flash the (par64's) bliders if you like.
- FreeStyler Version: Beta
dwebb1911
Perfect ! Thanks for the help. I am clearly just learning this stuff and really have no idea what I'm doing. Thanks Again !!
