ADj tri par profile Topic is solved
Katcha
ADj tri par profile
Post by Katcha »
Hello all,
does anybody get a fixture for FS for the great american DJ tri par profile?
Thx a lot in advance to who can post it or create it !
Thx .
Kat :fs:
Katcha
Re: ADj tri par profile
Post by Katcha »
Omg, nobody gets it or is able to do it?
grizcreative
Post by grizcreative »
Post a link to the instruction manual and I will create one for you
Sent from my SCH-I500 using Tapatalk 2
Katcha
Post by Katcha »
Hey,
Thx a lot, it is very kind of you.
here you can find the link.
Thx again !
Up and right on this page, you can get the manual on PDF.
http://www.americandj.com/ProductDetail ... umber=2085
Post by Jan_K »
Hej Katcha.
Think you need to tell what mode you want to operate the fixture in.
It can run in 1 to 7 channels mode.
Additional I think you should try to create the fixture your self.
It is the only way to get a feeling of what DMX light control is.
And this is a quit simpel fixture to create.
There are a tutorial that direct describe this type of fixture.
http://www.freestylersupport.com/wiki/f ... led_parcan
Katcha
Post by Katcha »
I tried, but doesn't work well.
It is ok with the colors, but not with, lamp on/off, strobe and dimm :(
Also seems that there are auto programms in...
Post by Jan_K »
Here is a first shot at the fixture.
Test it.
And open it in Fixture creator to see how it's made.
There may be some errors please correct them or comment it here then we can have a look on it.
American_DJ_Mega_Tripar_Profile.pff
(44.24 KiB) Downloaded 152 times
Note it is 7 channel mode and your fixture must be set to the same.
Katcha
Post by Katcha »
Thx a lot, i will keep you informed.
Thx for the time passed on it for me.
Kat
Katcha
Post by Katcha »
Works fine, for a lil test !!!
Another question to not disturb you again..;
How do I programm 6th DMX for this example?
I did 1 to 5 :) but on 6th there are dim up and down, than color mix etc and after sound active !
P64 LED DMX Values and Functions
Channel Value Function
1 0 - 255 RED
0% 100%
2 0 - 2 5 5 G R E E N
0% 100%
3 0 - 255 BLUE
0% 100%
4 8 - 255 COLOR MACRO
5 0 - 15 NOTHING
16 - 255 STROBING
6 0 - 31 NOTHING
DIMMING CONTROL
32 - 63 DIM BRIGHT
64 - 95 BRIGHT DIM
96 - 127 DIM BRIGHT DIM
128 - 159 COLOR MIXING
160 - 191 3 COLOR CHANGE
192 - 223 7 COLOR CHANGE
224 - 255 SOUND ACTIVE
i have taken a look at it but i doesnt realy matter as jan_k allways make the Fixture's Perfect!
look on the Macro tab From freestyler and all the marco / Colormarco / and Sound buttons are allready there :D
Well done jan_k ;)
Katcha
Post by Katcha »
And concerning the 6th channel of an other par, how do i parameter that?
Cause there is dim up
dim down, color mix
colorchange
and sound active?
6 0 - 31 NOTHING
DIMMING CONTROL
32 - 63 DIM BRIGHT
64 - 95 BRIGHT DIM
Post by Jan_K »
When you have made the other fixture the remember to upload them.
Thats a part beeing member of this forum. ;)
The other par fixture.
Depending of the adjustment idea place the dimmer on the dimmer channel with a rang and the rest as macros.
Eventually with show in function.
Post a link to the data sheet.
Then it is easier to guide you. :D
Katcha
Post by Katcha »
Hey;
for sure I will post a link, but for the moment, it is not working lol. Working for strobe, colors, but not for this 6th channel lol
Here is the link link :
http://www.americandj.com/pdffiles/64bledpro.pdf
Thx a lot for your precious help.
I have also made a Chauvet 4 spot CL that is working if somebody wants it...
