Hej Sinck
It is not that difficult.
I guess that your main problem is that you don't know what happens on this channel.
Turn on the whole system.
Turn on light, Dimmer and some colors set to full light.
In the right side of FreeStyler you will find 6 sliders for the selected fixture.
No 5. is the direct control for channel 5, move it.
Record each time something shifts.
This way you will get a table like this example from 85-94 color jump 1, 95-104 color jump 2.........
These values you can use to make a macro in Fixture Creator
You can just give them a number icon "1". And a hint use the middle value, 85 - 94 middle value is 90.
http://www.freestylersupport.com/wiki/f ... figuration
And finnaly, in Fixture Creator, Export the fixture and upload the pff file here the we will have a look on it.
