i want to use the Millenium DP1000 drum Pad via USB-to-MIDI interface to trigger sequences in FS.
(for a description of the pad see http://www.thomann.de/de/millenium_dp1000.htm)
Unfortunately, the thomann customer service told me that the DP1000 is not able to send note-off signals.. only note-on. Obviously, in some sound devices this will lead to a "cumulation" of notes playing
--> Is this a problem with FS? Does FS need a note-off signal to work?
best regards, Mario
