I've purchased some new fixtures and I'm finally getting everything controlled via DMX.
My issue is, I create a shape (or use an internal shape) in the Bezier portion of the Pan/Tilt window and then I create a sequence and add the Shape as a step the entire shape is done in 1 step. That means I'm not able to make the shape reactive to music or speed control via the sequences window.
Is there anyway to have each movement in the shape go to a new step in the sequence? If not, is there an easy to way to generate movement and make it steps? I tried the "FX" generator in the sequence window, but found it hard to figure out and not as creative/intuitive as the Bezier shapes.
Also: When I make a Bezier shape a one step sequence and add it to the sequences window it triggers fine. But then when I turn the sequence off, the fixtures do not return to their previous state like they do with all other sequences.
Thanks!!
