hi all,
i need some help on this one, i have sucessfully connnected to fs remotely with my iphone app using the tcp/ip server, the server is receiving commands ok but, it is not responding correctly, whenever i send a command all i get from the server as a response is FSOD. ie,when i push blackout it does not black out the server just goes to the next line in the log with FSOD, i have tried different ports, starting the net framework etc but to no avail.
i am using win 7 with no firewall or anti virus which might get in the way, i would have thought if it was a firewall issue i wouldnt get connected.
please help this is annoying me, i did get it all to work perfectly on my old laptop but my new one will not play ball.
matt.
i am using 3.4.6 (i think, not the very latest)
freestyler remote control issues Topic is solved
matt-the-dj
Re: freestyler remote control issues
fixed it myself, i found a posting i made early last year with the same issue on my old laptop,
i changed the port to 3332 then and it worked, tried it on new m/c and guess what? it worked.
woohhooo
there was a suggestion made on the original post that i do not need to use the tcp/ip server when using my iphone. could anyone explain how.
matt
woohhooo
matt
