I programmed a few one- or two- step sequences (i.e. blackout, all white etc.) and the sequence runs nicely in the preview and when triggered manually from the cuelist.
But as soon as I save the cue and assign it to a button, the sequence won't work anymore :-/
Is this a bug or did I do something wrong?
best regards, Mario
Sequence from CUE-Button not working Topic is solved
docMario
Re: Sequence from CUE-Button not working
OK, this is what I found out:
1) re-edits of fade and sequence times without subsequent renewing the cue (delete sequence, re-add it, save cue) seems to be a problem.
2) Pan/Tilt of one-step sequences does not get transmitted via cue-button, only when the sequence is triggert from the "play button" in the cue list.
does that make sense?
