Problem with new version
erajari
Post by erajari »
I downloaded the new version of Easy View, everything is working perfectly except when I try to export the stage I get an error message "Invalid file path"
Tried uninstalling/reinstalling...nothing.
I'm using 64-bit Win7.
I even tried it on another computer with Win XP, same thing happened.
Had no trouble with the older version, but since I don't have the install file for the older version, I'm stuck.
Can anyone tell me what the problem might be or what am I doing wrong?
Koshy
Re: Problem with new version
Post by Koshy »
I have the same problem with xp sp3
