I'm new to Freestyler. I have 3 Chauvet Q-wash 560z led lights that I am trying to make sequences with
. I'll be using these for stage lighting (theater,live acts). Basically what I'm trying do is create cues, for instance, sequence 1 would be center stage up full, sequence 2 would be black and then pan/tilt to next area. Here is my issue. I can only pan/tilt when the dimmer/ intensity is up. I cant move the lights in black with a sequence. Am I missing something?
Pan/tilt in black
smatts
- FreeStyler Version: 3.4.8
DELighting
Re: Pan/tilt in black
so, I'm guessing that you made sequence 2 with two steps. step one is to turn off the light, then step two moves the light? When you made the secquence did you allow enough time for step one to complete before set two goes?
