Strobe effects Topic is solved
djlootz
Strobe effects
Post by djlootz »
Hello, new to the forum here and Freestyler. I'm figuring things out slowly and I'm really starting to like the software! I had a quick question that I couldn't find in the wiki though. How would I black out all lights and activate my strobe light all on one hotkey? I figured out how to put the strobe light on the override keys but my other lights are over powering my strobe when I use it! And one more question with regards to strobe effects, is there anyway I can have all the lights (chauevt led strips and chauvet led scanners) strobe simultaniously in the current sequence they are in with a toggle hot key kind of like the strobe light mentioned above? Let me know if that was confussing and needs any clarification and thanks for any help! :fs:
Re: Strobe effects
Hello.
Yes the first one is possible and not that hard.
but the second one is Realy hard to get it right.
for the first one you just create a Sequence that says Stobe ON and all the other lights off and put in on the override buttons
now the second quastion.
you create again a sequence with all the lights strobo ON only you need to set the Flash rate the same as the on all the lights.
and put it on a Override button.
