American DJ Mega24 Pro Fixture Profile Request Topic is solved
reikikoby
Post by reikikoby »
Hello I am seeking a profile for an American DJ Mega24 Pro light.
I would prefer the 16 channel mode but the 7 channel mode will work too.
Lemme know if there's a profile out there already,
:fs: :geek:
cheers, Koby
UniCav
FreeStyler Version: 3.5.2
Re: American DJ Mega24 Pro Fixture Profile Request
Post by UniCav »
Koby have you found or created one yet? I'm just setting up FreeStyler and we have 2 Mega24-Pro's. I want to run them in the 16 Channel Mode myself for full control.
UniCav
Post by UniCav »
If anyone has an American DJ Mega24 Pro can you test this file for me? I created it yesterday, my first fixture file. I don't have my USB adapter yet so I can't test it myself.
Mega 24Pro-16ch.pff
American DJ Mega24 Pro 16 Channel Mode
(78.32 KiB) Downloaded 79 times
Post by Jan_K »
Hej UniCav
I don'thave the fixture but I think you have mave an error in the strobe channel.
You have given it channel 13. In the manual it is suppose to be 14.
Also fill in you name date and mode (16 ch) in the info box.
Finally the maga 24 pro have 4 RGB segments.
I think you should try to use the segment control. ("RGB segment") there are a tutorial on the wiki of how to use this.
http://www.freestylersupport.com/wiki/f ... t_tutorial
Edit// Fixed broken URL by Nathanrs93
Post by Jan_K »
Here is a 10ch mode have a look on the segments and the macros.
American_DJ_Mega_24Pro_10ch.pff
(79.2 KiB) Downloaded 83 times
UniCav
Post by UniCav »
Jan that seems to keep happening every time I set up the fixture and save and export it the next time I open it up the channels have been rearranged. Not sure what the deal is with that. The first couple of times I opened it and it was changed I thought I did something wrong but now I'm wondering if there's a problem with the way Freestyler 3.5.2 is saving it. You're 100% right on both counts but I'd swear that's how I had it set up when I saved and exported last time. I'll edit it again and add my name and date to the info. Thanks for that tip. I'll look up the wiki on the color segments too. On the same subject what about the strobe/speed channel on Ch 14 where in Speed mode anything above 240 is for Sound Active. I saw a switch for that in FS should I set up a macro or something to toggle that?
UniCav
Post by UniCav »
2nd Version of the 16ch mode with RGB Segments if anyone can try it out thanks
Mega24.Pro.16ch.v2.pff
ADJ Mega24 Pro 16ch with RGB Segments
(78.42 KiB) Downloaded 77 times
Post by Jan_K »
If you can replicete the error where it is the wrong channel that are saved then file a bug report on it. :)
At the moment I have reported one with the RGB segment where I don't have the color selection part meaning that I am not able to set the color on the segments.
Regarding the strobe - sound.
If you look at the fixture I created then I have moved all programs to macro instead of using the gobo.
Additional I have made the sound as macro and used the "show in" function so it is shown in the beam panel.
(I forgot to use "blank" ikons on the not used macros so there are some red X in the macro panels)
I find that it is a good way to do it but others may think different and in that case you actually need to try it out to figure out if it is the way to do it or if you think it is confusing your fixture and then eventually don't add it to the fixture.
UniCav
Post by UniCav »
Thanks Jan I'll check it out that way. I'm still timing the purchase of a USB adapter so I can really start testing this in reality. I Seriously thought about using the macros instead of the gobo it kind of makes more sense to me as well so I'll look at yours and compare. Just got my 8 SlimPAR 64's in and my bassist has an awesome laser that we haven't even tried playing with the DMX options on so this promises to be really exciting.
UniCav
Post by UniCav »
Jan I finally got my DMXking adapter in and hooked up one of our Mega24 Pro's and it worked great. I removed the Gobo's from my 16 channel version and the RGB Segments since it really doesn't help with this fixture and added the Macros. It's really cool that you can switch between a Color Macro and use Strobe or activate all 12 available LED channels and use Strobe or use a Program and adjust the speed. Now to get my SlimPAR64's hooked up and learn how to create sequences and program songs for our show. About drove me nuts this weekend running all the LED's on an Elation 16ch board while singing haha.
Mega24.Pro.16ch.v3.pff
Mega24 Pro 16 Channel mode with macros
(80.16 KiB) Downloaded 67 times
