QTX Quartroscan led Topic is solved
msg00001
QTX Quartroscan led
Post by msg00001 »
I have a quatro scan and finding it hard to control the 4x scanner unit. Can anyone give advise how to do it. new to freestyler
Re: QTX Quartroscan led
hi
Did you allready look at the wiki:
http://www.freestylersupport.com/wiki/freestyler
msg00001
Post by msg00001 »
yes had a look but is it possible to create a fixture because mine is not on the list
Post by Jan_K »
Hej msg00001
If you have the Manual / DMX table then it will be no problem to guide you.
Please upload the manual or link to it.
