HELP WITH MOVING HEAD LED
Dakar ZA
FreeStyler Version: 3.4.6
Post by Dakar ZA »
Hello, Can somebody tell me if you only want to have a fixture to pan and tilt within a certain range can you create the fixture with the limits you want it to operate in? Thanx :?:
Re: HELP WITH MOVING HEAD LED
between the freestyler setup you can have a Pan/tilt Resize.
i think you mean that.
Dakar ZA
Post by Dakar ZA »
Hi Spirit, Thank you for the reply. I am still battling to get this light operating as I want it to work. What I mean about the pan and tilt is if it is mounted in a corner and I do not want it to pan and tilt to the back as there is a wall. Do I then create the fixture to only pan and tilt within the degrees to the front. Also the gobos is sometimes only 50% of the lense. I am not winning at this stage. All help appreciated ;)
Yes this means you just need to make Sequences with the Correct Pan and tilt so it will not beam on the wall.
and if you Gobo does this Sometimes it can mean that there are Faulty Motors and you need to Replace the Gobomotor.
If your sure you made the Sequences correct.
Dakar ZA
Post by Dakar ZA »
Thanx Spirit,
I will re-check all the settings. I do not think it could be faulty as in the auto mode all the gobo's is fine. The settings might need to be fine-tuned. I will upload for your input once I am done.
Regards Herman
