Colors don't change between sequences
sgarner4
Hi, I am very new to FreeStyler and am really enjoying it so far. I have run a couple of shows live for a band, but not in the last 3 weeks. When I finally got back to programming new scenes/sequences, I ran in to a problem I hadn't encountered previously: the colors from one sequence bleed into the next. Meaning, I programmed a simple sequence with only a couple of steps that engages the movers only in blue while twisting. I saved that sequence, entered into que, and began a new one that was supposed to be all red. Basically, after creating and saving each sequence, when I go to play them back the color from only the 1st sequence manifests itself, even though the movements change correctly with each new sequence selected for playback. I'm stuck. Again, it's been a few weeks since I've worked in the program, but did not change any settings since last time I did. Please help, I've got a show tomorrow! Thanks!!
- Spirit
- FreeStyler Version: 3.5.9
Re: Colors don't change between sequences
Maby you can send a Backup file.
beacuse its not realy easy to see what you did without the Sequences you created.
