EUROLITE DTB-405 4-channel dimmer bar 5A
- FreeStyler Version: Beta
Re: EUROLITE DTB-405 4-channel dimmer bar 5A
Hej Noldy
You don't need any special driver for this one.
It is only working as 4 dimmers.
You just need to add 4 parcan fixtures and you are up running.
Goto "Add / Remove fixtures" and find the folder "PARCAN" and selec / add 4 fixture.
////////////////// From the manual. ////////////////////////////////
6. OPERATION
The DTB-405 Dimmer Bar is used either as a 4 channel chaser controller or a DMX dimmer pack. It has two
operating mode: MASTER and DMX, which is corresponding to the receiving and transmitting functions
respectively. In DMX mode, it features 4 channel individual DMX address setting. In MASTER mode, it is
incorporated with 6 operating modes, MANUAL DIMMER,MANUAL PROGRAM, AUTO PROGRAM, HOLD
SOUND, PROG SOUND and AUTO SOUND.
6.2 DMX mode
When the DMX indicator is lit, this unit is used as a DMX dimmer pack, Display shows "DMX".
6.2.1 Set DMX address of any one channel
Press channel button ,corresponding indicator will blink, and the DMX address of corresponding channel will
appear in DISPLAY. Using up button or down button to select desired DMX address followed by pressing
corresponding channel button, corresponding indicator is off indicating information of entry is confirmed.
Then the information in DISPLAY screen returns to initial condition.
6. OPERATION
6.2 DMX mode
