i have a intimidator 1.0, and know how to use almost everything, but there is one thing i don't know how to do. In the pan/tilt window, you know the preset "shapes" that the light follows when you click go? Is it possible to draw your own shape in there, or do you have to modify a premade one?
thanks
Pan/Tilt?
- Lightman
- FreeStyler Version: 2.95f
Re: Pan/Tilt?
i have 2 intimidator 1.0's.....do you have a fixture file for them? I dont have one so i cant even use myne on freestyler?
thank you
thank you
- FreeStyler Version: 3.00
Re: Pan/Tilt?
Select an existing shape, click on the edit button, and then save it under a different name. Easy as 1 2 3.
Remember to set the spacings between the dots equal, otherwise whilst following the shape, it will go quicker over the longer gaps, this leads to quite an uneven movement of the light.
Does that help?
Does that help?
