I have been using Freestyler for some time but usually only with a standard keyboard (or USB number pad).
I am now upgrading to using a midi keyboard which is working fine for most things like selecting scenes etc however I have tried to assign one key to the smoke machine but when the first time I press and release the key the smoke machine stays on and I have to hold the key down to stop it.
Is this normal behaviour is am I missing something? Is there a way to invert the key?
Tom
MIDI Keyboard and smoke machine
fbnts
- FreeStyler Version: 2.96d
There are 10 types of people in this world = Those that can read binary and those that can't
- Spirit
- FreeStyler Version: 3.5.9
Re: MIDI Keyboard and smoke machine
Yes there is a way, if you open the FOG window you can Choose "Continuous Operation" disabled or Unabled.
thats how you can change the way the FOG button will work.
fbnts
I have just got round to trying again, the continuous box is unchecked. It appears to do it with all buttons. When you first press the key down it activates when you let go then you have to hold the key down to deactivate... it's as though it's inverted.
Any ideas?
Sent from my Galaxy Nexus using Tapatalk
Any ideas?
- Spirit
hi.
try this: http://www.freestylersupport.com/wiki/e ... _interface
and search for "Options" maby that will solve your problem.
