I plan to use Freestyler for our Easter program. The program is a timed program running on DVD with music and video. I plan to setup all the lighting as sequences and add them to a cue with the DVD running time set for each sequence. I've run a few tests and everything looks good. However....
This is my question, I need to be able to start the timer at the appropriate time. Currently I have to click on the button with the mouse. I would like to have a keyboard command to start the timer. I can't find a place to set it in the keyboard setups. Does anyone know a way to set a keyboard command to click the "Start Realtime" button on the cue window?
Keyboard control for the "Start Realtime" button
garykhensley
- FreeStyler Version: 3.4
- I Use FreeStyler for: Choir
