Contest Scn 950
zoran
FreeStyler Version: 2.95f
Contest Scn 950
Post by zoran »
Hi Everyone !
I'm currently preparing a show with FreeStyler.
A lights shop will borrow me a Contest Scn 950, but I can't find a fixture file wich could be suitable.
I tried to create one but a simple element is missing : what are the basics gobos of that fixture ? :?
Can someone help me ?
(sending me the fixture file or gobos list ... ?) :cry:
Thanks a lot for any help you can provide to me ! ;)
Android Dev (Moderator)
FreeStyler Version: BETA
Re: Contest Scn 950
Post by Mattotone »
Help us to help you! If you need help creating a fixture please try and find the location to a downloadable manual before posting or attach the manual to your post! Otherwise you may get little or no help.
zoran
Re: Contest Scn 950
Post by zoran »
I think this rule doesn't apply...
I mentionned I tried to create one fixture but something missing : the default gobos...
My question is : has somebody the lust of those gobos ? or if I'm lucky maybe someone has already the fixture configured...
I searched on the web to answer my question, but I didn't find any answer, I hoped sombody could help me ...
Re: Contest Scn 950
Post by Mattotone »
if you can find the manual the gobos are usually contained in there.
then someone can either make the gobos or make you a fixture.
or maybe find a gobo set o the net that fits
zoran
Re: Contest Scn 950
Post by zoran »
Mattotone wrote:if you can find the manual the gobos are usually contained in there.
Thanks a lot for your answer ! As you can imagine, I found the technical documentation, but as the gobos disc can be changed, they don't give the default ones ...
Poor me !
PS : I have contacted the main distributor of Contest in France, I hope maybe they can help me !
zoran
Re: Contest Scn 950
Post by zoran »
Thanks to Olivier PASTOR from hitmusic.fr !
He gave me a photo of the gobos !
If you're intrested : http://www.hitmusic.fr/gimages/scn-950_ ... bodrot.jpg
Re: Contest Scn 950
thats great hae u added them to the fixture? if u havent i will at some point!
zoran
Re: Contest Scn 950
Post by zoran »
I'm curretnly trying to make my fixture work with Martin Light Jockey, but it's not easy, I will post here all the work when it will be tested and Ok.
Re: Contest Scn 950
posting a light jockey fixture file probably wouldnt be well recieved in here :D :fs:
zoran
Re: Contest Scn 950
Post by zoran »
Of Course ... What I ment is : "I will post the Freestyler fixture file when I will be really sure that it will work !" :mrgreen:
