Please help to create Fixture files (Lemon Led spot 10)
lesena
Post by lesena »
Please help to create Fixture files (Lemon Led spot 10)!
I tried to do myself, but what did not work always comes out the error (Please fill all gobo values)
I have a manual for this device. can send the mail to me who is able to create a Fixture files Lemon LED Spot 10
lesena
Re: Please help to create Fixture files (Lemon Led spot 10)
Post by lesena »
Here are two references to himself arrived, and you can download the manual.
I ask all who can help help!!
http://www.asiamusic.ru/catalogue/produ ... 3048623742
http://www12.zippyshare.com/v/24759512/file.html
Post by Jan_K »
Hej lesena
The error you refer to comes when you have defined that there are some gobo but you have not filled in the values.
If you click on the Gobo wheel "Tab" in Fixture Creator then you will have a table with no values in.
If you don't have the values then just add some and you should be able to save your work.
Remember to do it on all the gobo wheels that you have configured.
Eventually have a look on some of the wiki pages.
http://www.freestylersupport.com/wiki/f ... figuration
lesena
Post by lesena »
Thank you so much! But I already did! You correctly pointed out the problem. But I figured out earlier.
Post by Jan_K »
Hej Again lesena
If you find error in the wiki when you try to follow the tutorials then give a us a feedback so we can correct or clear it.
I added your fixture in the other topic you posted on with the 1 - 7 channel fixtures.
