Would someone like to help me create a file for this laser.
QTX LS-Emerald
http://avslgroup.com/en/product/152.751UK
QTX LS-Emerald.
- FreeStyler Version: Beta
Re: QTX LS-Emerald.
Hej Rowl3y
You need to find the manual for this device else it will be extreme complex to figure out how it works.
Laser can be very complex to make fixtures for and without manual you have to figure out what each channel does by the “try and error” method
Some of the channel control may have more functions depending on what the other channels are set to so this can be complex.
