chase / cue folder is 3.4.6
Koshy
FreeStyler Version: 3.4.8
Post by Koshy »
I do a lot of my freestyler on my dekstop and then backup and restore it on my laptop .
If you have all your Chases and Cues organized in sub folders as I do
Example
Chase\Par\Par Colors \ Sequence
Chase\MH\MH Movement\ Sequence
Chase\MH\MH Prism\Sequence
When you install a fresh copy of freestyler and then restore a backup you will get an error
Runtime 67 , To many files
If you manually copy your chases and cue folders from your target machine to your destination machine and then restore your backup, it then worked properly for me
Re: chase / cue folder is 3.4.6
please report this to the Devolper on the Bug tracker.
http://www.freestylersupport.com/bugs/main_page.php
