mouse hold on pan / tilt
Jaykie
Post by Jaykie »
This is fom the old forum
Wouter-W
Is it possible to create a hold function in te pan/tilt window that if you click once on te blue spot for the fixture position it keeps active until you click a second time.
When using a trackball it could be verry handy, and it works easyer.
Skylight
I also used an trackball, when holding the mouse on the blue-ball, click the middle button of your trackball, it will stay clicked on the ball.
(so you can freely move the trackball without holding down the left mousebutton.)
Return to “Ideas and Remarks”
