American DJ Fusion FX Bar 5 Topic is solved
DJPaul
Post by DJPaul »
Any chance anyone would be able to make a file for the ADJ Fusion FX Bar 5?
Re: American DJ Fusion FX Bar 5
Post by Jan_K »
Hej DJPaul
This one is a bit special and I think you are to do the fixture by your self.
As I see it this is 3 fixtures in one and my advise is to make 3 fixtures and use them as combined fixtures.
All that info is available on the “Wiki”
If I was to do it I would make a 1 channel fixture for the White strobe.
A 3 channel fixture for the moon flower.
And a 3 channel fixture for the laser.
DJPaul
Post by DJPaul »
Okay thanks, thats kind of what I was thinking. Ill try it out.
Post by Jan_K »
I have made a suggestion to the 3 fixtures that you are to combine.
Unfortunately they have an error there is a movement panel present.
It is a bug and has been reported but you can try it.
American_DJ_fusion_fx_5_Strobe.pff
(4.28 KiB) Downloaded 67 times
American_DJ_fusion_fx_5_Moon_Flower.pff
(21.79 KiB) Downloaded 63 times
American_DJ_fusion_fx_5_Laser.pff
(18.6 KiB) Downloaded 59 times
You can find some info on the combined fixtures here. http://www.freestylersupport.com/wiki/f ... d_fixtures
Post by Jan_K »
Okay.
The bug with the movement panel has been removed and here are 3 new files.
(4.29 KiB) Downloaded 78 times
(21.8 KiB) Downloaded 73 times
(18.61 KiB) Downloaded 66 times
DJPaul
Post by DJPaul »
Thanks, I ended up creating custom ones anyway (well, editing your originals a bit) and they worked well. Thanks much for everything!
Post by Jan_K »
Hej DJPaul.
If you have anything working then export it upload it here so other can try it. ;)
