I started to 'play' with FS (v 2.95f) to get the feel of it and see if it can replace my 'heavy' controller board.
I really like the concept of viewing the different parameter levels of each attribute and the group programming.
I came across some problems and I would appreciate any assistance to see if they are bugs or am I simply missing something.
1. I loaded (through the fixture creator) a fog machine that uses 2 channels. I set them to 500 and 501.
I can operate these channels 'manually' by sliding the bars when selecting the fogger but the fogger is not activated by the fogger control window.
In fact, I could not find anywhere where to update the program which dmx channels are assigned to the fogger.
2. I am trying to program simple dimmer scenes and to run them sequentially as in a 'normal' board using the GO button to progress from que to que.
Programming the scenes with fade times into ques goes ok.
However I could not find the proper routine to accomplish the playback as desired.
3. When populating the que list window, sometimes a button on the list gets stuck (stays in red) and the table is not responding.
4. Also, on the que list, only some of the populated lines (sometimes only one) show the relevant time values (in the timing columns) the rest are empty.
Any guidance would be appreciated.
Thank you in advance,
N.Webber
