First post and asking questions so sorry! Not sure if this has been asked before or indeed if I'm posting in the right place!
I currently use Freestyler to control 4 Acme Dynamos and 2 EVL spins and the results I must say are nothing short of impressive, so thank you for some fantastic software. My question however is while each show is running on these lights being triggered by S2L, is it possible to have another show running to say control colour fade on some uplighters? (If that makes sense)!
Thanks for any advice,
Mark
Running 2 Shows at Once! Topic is solved
- Spirit
- FreeStyler Version: 3.5.9
Re: Running 2 Shows at Once!
hi,
Read this and it may Solve your problem:
http://www.freestylersupport.com/wiki/sound_2_light
biglardyboy
Thanks for the info, will have a look over the weekend. Think I might have found the answer I was looking for......
Setup -> freestylerSetup -> preferences
Then select the cue multiselect always enabled
Am trying it the weekend, hopefully this will do what I need.
Thank you for taking the time to reply.
Mark
Mark
