Save as "sequence 1"
twaga
- FreeStyler Version: 3.3.2
How can I assign an edited sequence to "Sequence 1" which appears in the function list of MIDI control setting windows?
- Spirit
- FreeStyler Version: 3.5.9
Re: Save as "sequence 1"
http://www.freestylersupport.com/wiki/p ... k_sequence
look at this page, and you see Sequence 1 to 20.
twaga
I did as indicated in the URL, but lights didn't move at all.
In the each sequence edit window, lights move to the last step when I push the stop button.
Is there a youtube movie showing how to do with sequence in which someone moves lights actually?
- Spirit
I did a Quick try , and it seems to work Fine.
Drag and Drop a Sequence to the CUE.
Press "Start Sequence 1" and the Sequence is playingback.
Press "Stop sequence 1 "and it Stops on the Current step.
Also "Sequence1" button work ok.
twaga
Thank you very much.
I also found this:
http://www.youtube.com/watch?v=_CJgmjyM9Os
Lights move well instructed by Sequence 1 in the first round, but it didn't repeat.
Could you do a quick try the repeating sequence?
I also found this:
twaga
Sorry, I took a mistake on URL and I corrected in the above.
- Spirit
oke first of all , Great Job that DJmikymike Does.
I have seen many of his Video past bye.
But i would not make a Tutorial about a software i Do not Master. Also somethings that mikeymike says isnt Realy correct.
But about the Repeat, If you go to the Previous Page i Showed you.
And you go To "Other Cue Functions / Options" you see a List with Icons and there Function.
Here you can Find how to let a Sequence Repeat.
/Spirit
/Spirit
twaga
I uploaded a youtube movie that indicates the situation of fail to repeat a sequence.
http://youtu.be/R25pyVz6Ehs
I think the sequence was set to be repeated.
- Spirit
hi
In some Rare Cases you have Your Unicode Diffent then US.
Like Asia languages use 2 bytes to represent a character, English just only one. Sending data to the com port will give problems when value gets higher than 127.
Maby this can help you out: http://markcz.wordpress.com/2009/07/10/ ... -computer/
Look at this i noticed that all the Pages you gave where asia
/Spirit
/Spirit
twaga
After changing my computer's language to English US, but the sequence didn't repeat.
If the language doesn't cause, I think the cause is USB-DMX interface?
My interface is daslight which is unofficially supported by selecting "DXPACK" as the interface.
What are you using as the USB-DMX interface?
Could you try to repeat after changing your computer's language to Japanese to know whether the language really causes?
twaga
In addition, My OS is Windows 7 32bit.
- Spirit
The OS Doesnt matter. The thing about the Language is that Asia Uses "2" BITS to Create a character, and US uses "1"BIT to create a Character.
But i'm Not Going to Test this, And maby Mass everything on my PC.
There is One thing you can try to see if this is caused by the DMX device.
On the Toolbar from Freestyler you see "File", "Edit", "Fixture", "stetup", "Plugins", "OUTPUT", "Windows" and "Help"
Now if you press on "OUTPUT" then on "SHOW OUTPUT".
Here you can see all the data thats Being send from Freestyler to the DMXDongle.
Now Compere this, and see if the Output does the same as what the Fixture does.
