Chauvet Rotosphere can't get strobe channel to work Topic is solved
djrobentertainment
Post by djrobentertainment »
How do I upload a fixture file It says .fxt is not allowed? I'm really stuck
dmxlighting
FreeStyler Version: beta
Re: Chauvet Rotosphere can't get strobe channel to work
Post by dmxlighting »
use the export feature in the fixture creator. Then upload that!
dmxlighting
when u upload it please also upload a fixture profile document too
djrobentertainment
Here u go
Rotosphere.pff
(34.55 KiB) Downloaded 68 times
Chauvet Rotosphere.gif (3.93 KiB) Viewed 713 times
oke for the Strobe you can Use the Strobe section with in Fixture creator.
so Strobe ch. = 3
Off = 0
Low = 10
med = 132
high = 255
Also look at: http://www.freestylersupport.com/wiki/f ... figuration
http://www.chauvetlighting.com/products ... _03_WO.pdf
djrobentertainment
I tried that but the lamp/strobe option is not showing up on freestyler when the values are entered
djrobentertainment
Yes i see it your right.
Then i would recommend to add Channel 2 to the Shutterch. And only Fill in Closed = 0
With the Shutter closed you now also have a Working Blackout ;)
And also Clear Channel 3 From GoboCh. 3
djrobentertainment
Now low and medium strobes give no light at all and off is slow strobe and high is ok
djrobentertainment
Sorted now thanks!
Rotosphere..pff
(30.84 KiB) Downloaded 63 times
djrobentertainment
Only thing now is the sound to light isn't working
oke Automatic and Sound modes is on Channel 4.
You allready added Channel 4 to Gobowheel 2, thats ok
Now Gobowheel 2 haves 3 gobo's, No function, Automatic and Sound modes.
No function = 0
Automatic programmes = 127
Sound modes = 253
djrobentertainment
Thanks man!
