sequence by MIDI control
twaga
FreeStyler Version: 3.3.2
Post by twaga »
What is the difference between "sequence 1" and "Start sequence 1" given as a function in MIDI control setting window?
Re: sequence by MIDI control
Sequence 1 ~ 20, thats a Toggle button.
Press one time and the Sequence PLAYs and press a Second Time and the Sequence STOPs.
Start Sequence 1 ~ 20, its a Flash button.
and if you press it, i will only PLAY the Sequence.
Thats way there is also a STOP seqeuence 1 ~ 20.
Because that one will STOP the Sequence
/Spirit
