Fixture request American DJ Flat Par Tri7x Topic is solved
Koshy
I am looking for a 7 channel fixture file for the American DJ Flat Par Tri7x
http://www.americandj.com/pdffiles/flat_par_tri7.pdf
If anyone can help me with this it would be greatly appreciated.
Koshy
Re: Fixture request American DJ Flat Par Tri7x
Actually I think I need 6 channel mode
1 = RED
2 = GREEN
3 = BLUE
4 = COLOR MACRO
5 = STROBE
6= MASTER DIMMER
1 = RED
2 = GREEN
3 = BLUE
4 = COLOR MACRO
5 = STROBE
6= MASTER DIMMER
- Spirit
- FreeStyler Version: 3.5.9
Go to this page: http://www.freestylersupport.com/wiki/f ... arcan:tour
This page show you how to create a Nice looking Ledcan
And just ignore the Channels you don't Have.
/Spirit
/Spirit
Koshy
I created a 7 channel Fixture file to the best of my ability.
Untested b/c the pars have not arrived in the mail yet.
I would like to Create macros for all the white's from 3200k to 10000k
I am not sure if that can be done with a TRI color or if you have to have a Amber / White LED in the fixture
If possible could I get the Red Green Blue Values to come up with all the different Whites ?
Also , How do I make the Flat Tri 7 fixture for the easy view visualizer?
Thank you for the help SPIRIT
amdj Flat Tri7x.pff- (56.01 KiB) Downloaded 119 times
- Spirit
hey koshy
allmost Spot on
You added channel 7 to the Shutter but thats not Nessecery.
And about the 3200K to 10000K
Thats difficult, Because the Page i Showed you that led par did have some Premade macros from the Factory.
and your Fixture doesnt have these Premade macros. and you dont neccery need a White channel to Achive the 3200k to 10000K. its also possible with just the RGB channels.
The only way to get these Colors is if you got Realy! good eyes. or some Expencive Hardware.
allmost Spot on
Koshy
Do I need to remove channel 7 from the shutter ?
I Saw this
R B G W
255 168 0 83 (White 2700K)
255 180 0 155 (White 3200K)
247 214 19 255 (White 4200K)
217 251 50 255 (White 5600K)
168 255 84 255 (White 8000K)
and was hoping there was something similar for RGB Even if it was anywhere close I would be happy .
I work at a publishing company and we have a bunch of color swatch packs. Could I manually match them to the color swatches ? Is there e technique I need to follow ?
( Don't we all wish we could afford 32 ColoRado's w/ Zoom )
I just do concerts and no film stuff but I think it would be great feature to be able to choose correct white shades.
Thanks for the help man !!
I Saw this
R B G W
- Spirit
Yes i would recommend to Remove Channel 7 from the Shutter channel.
And about the CTO and CTC.
yes indeed i gave them as GUIDE LINES. From the Robe robin 300Ledwash.
And the Big Problem about leds are, Every Ledcan have its own type of Led.
Also the Colorpallet from freestyler isnt Correct If you realy like to have True colors, you need to Sort this out on all the Differnt types of Led.
And thats also nice about the ColorMarcos you have, Beceuse these are True colors. calibrated by the Factory
Maby You allready have CTO and CTC between the Colormarcos But there Names are Differnt.
And 3200K looks like a Warm old lighting bulb.
and 10000K looks like a Ugly WhiteBlue LED
/Spirit
/Spirit
Koshy
So How can I get them to work with the Magic Easy Viewer ? Is there already a 7 channel par this the same channel setup ?
Koshy
Never Mind , I saw it on the sunlight website. thanks for all the help man !!
- Spirit
No thanks
