Hey Guys ,
everything is based on this thread:
viewtopic.php?f=7&t=4112
I have Download the Bomes Translator to use my APC20 with Freestyler.
Why Freestyler sends only the Note B0 30 00 ?? ( Override Buttons )
I need different notes so that the apc is working... how can i do that ??
that my routing
APC out -> Translator -> midi Yoke 1 -> in Freestyler
Freestyler out -> midi yoke 2 -> Translator -> APC in
have anyone an idea for this problem ?
Midi Routing & Bomes Translator
Kiter1988
- FreeStyler Version: latest
- Spirit
- FreeStyler Version: 3.5.9
Re: Midi Routing & Bomes Translator
Sorry i realy dont have a Clue what you mean.
Maby you can upload the .BTMP file from Bomes midi translater.
so i can take a Look at what you allready did, so i can anwer you question better.
Kiter1988
ok i load it up
But this is only a test setup, maybe you can tell what my problem is or write it correct.
http://www.Deister-Sound.de/APC2.bmtp
right click to save
ok i load it up
right click to save
- Spirit
oke strange the .Bmtp file seems to be Empty..
Do you have more then One Note assigned in the Midi setup from Freestyler? For the Overridebuttons.
The amount of Midi notes Assigned to a Function will be Send back to the Midi controller.
How many Tanslators do you use?
/Spirit
I dont understand this one.Why Freestyler sends only the Note B0 30 00 ?? ( Override Buttons )
/Spirit
