I've been tasked with providing a few extra lights for a small stage pantomime in the local church.
Quick question for par 64 RGBW cans - which is best if the total combined wattage is the same? More 3w, or less 8w? Forget about different quality between manufacturers etc etc, I'm just talking brightness.
Cheers.
RGBW Led - Which is best?
- dmxlighting
- FreeStyler Version: beta
Re: RGBW Led - Which is best?
You will need a lot of 3w leds to keep up with 8 watt leds. I sell an 18x8 watt RGBW in a par 64 style.
Retail is £275 plus vat per unit. Its easily as bright os a par 64 lantern. 40 degree beam. sold hundereds of them and never seen one come back. (BTW you will not find THIS product being sold on the web)
mr_rodge
Hi there,
Thanks for the reply. I know that 8w are brighter, but what I'm getting at is for instance, if I have 3x8w LEDs up against 8x3w, they are both supposedly 24w. Which would give off more lumens?
Thanks again.
Thanks again.
- dmxlighting
Thats a tuff one. In theory they are both the same but this is not really the case. The 8w should appear brighter BUT this is also down to the optics which do most of the work really.
3x8w and 8x3w will both be crap. I would not waste the money UNLESS you can see them and know that you are happy with the output.
How much are these units ? who makes them ?
mr_rodge
They're not real products, just hypothetical. What I was looking at was a chinese 'knock off' on ebay that had 54x3w LEDs and I was wondering how it would stack up against an 18x8w can. (162w vs 144w). Thing is, it's half the price and has a guarantee so if I get half the brightness I'll be happy.
- dmxlighting
What you must remember when buying anything cheap it will in the end just be a load of crap.
Ive seen loads of these kind of units that go wrong quickly. LED does get hot and needs that heat to be displaced by well designed heat sinks. The cheap ones don't have that. This is why they stop working.
Its false economy to look at cheap shit on fleabay. Buy well and buy once.
Our units are warrenteed for 3 years and have 100,000 hours life (thats over 11 years!).
Beat that China!
Beat that China!
7clighting
Of course the brightest the better,but the cost is high also.
My suggestion is consider it from the stage size,small size with the simply parcan is ok,if big size with hi power LED parcan.
