Stopping sequence dosn't shut off lights Topic is solved
vinjkit
Post by vinjkit »
I am probably making a pretty dumb mistake somewhere but here it is anyways. The lights function fine during sequence playback but when I stop it the lights continue to hold in the step that they were stopped in. Is this the way they should work or is there a mis-configured setting. Do i need a DMX terminator?
Re: Stopping sequence dosn't shut off lights
Hey,
You can use the "Restore Values" Feature.
its located on the CUE and it looks like a Blue arrow.
http://www.freestylersupport.com/wiki/p ... k_sequence
gjgrech
Post by gjgrech »
vinjkit wrote:I am probably making a pretty dumb mistake somewhere but here it is anyways. The lights function fine during sequence playback but when I stop it the lights continue to hold in the step that they were stopped in. Is this the way they should work or is there a mis-configured setting. Do i need a DMX terminator?
It also happens to me. did u find a solution?
No, the devolper says that All the User liked to have Value "0" if you use "Restore value"
But maby you can use "Invert channel", But there is a Bug with that Feature.
But the Devoloper Sad that he will fix that one on the Next release.
