return to default value after a sequence Topic is solved
boekiewoekie
Post by boekiewoekie »
I have a question about returning to a fixed position and default value after running a sequence in the que.
I'm using movingheads (Studio Due Giant) and created the fixture for this MH, including the default value for the position and shutter.
Everything works fine, but when i stop the cue, the MH keeps the shutter open. (default value entered = 255 = closed)
So after a MH sequence, i have to close the shutter with the shutter button.
What am i doing wrong, or is it a bug?
Thanks!
Martin
Re: return to default value after a sequence
Hey,
You can use the "Restore Values" Feature.
its located on the CUE and it looks like a Blue arrow. "
http://www.freestylersupport.com/wiki/p ... k_sequence
boekiewoekie
Hey Spirit,
Thanks for the response,
I already used the restore values function (of course)
this works for other fixtures / sequences, but not for this one.
Martin
Hej, martin
Oke so there is one Sequence that doesnt work.?
can you upload the Fixture file as a .PFF and upload a Backup file so i can see whats going on.
/Spirit
boekiewoekie
Hey Spirit,
I uploaded the pff and a backup file with this post.
I hope you can help me!
Regards,
Martin
MH.zip
(203.94 KiB) Downloaded 50 times
Giant.pff
(26.33 KiB) Downloaded 62 times
Hej Boekiewoekie
I have lookt at it and your right this seams to a Bug i will report this and i think he will fix soon.
So wait to for the next Beta version.
And as tip for now.
Just make one Cuelist button that Says Everything OFF.
So if you like to stop the Curent running, Dont press it again But Press the ALL OFF Cue..
This way you can be 100% Sure that all the Fixture Goes back how you like to have it.
Met vriendelijke Groet, Spirit ;)
boekiewoekie
Thanks for the tip!
I will wait for the next version.
Groeten terug! :-)
