how to save settings
tcleary
Post by tcleary »
ok I added my fixtures and set them all how I want. how do I save the current settings for all my fixtures? if I click on "save as favorite" that works and I can always restore to my favorite. but how do I save a bunch of different "scenes" instead of just my favorite? I want to have a bunch that I can easily switch to. there has to be a simple way to do this I just can't seem to figure it out. much thanks for any help.
Tim
Re: how to save settings
Here on the http://www.freestylersupport.com/wiki/freestyler freestyler Wiki you can find allot of info about freestyler.
and u can use the Fastcue button On press and 20 Sequences run at the same time.
You can just use the cue to playback the Sequence you like to playback.
Submaster Also used on Prof Lightdesk For more controll of the Fixture.
And Override buttons , That only play the first step from a Sequence, Just like a Button On or OF, or Flash.
And to Create the Sequences Use Sequence Creator.
/Spirit
