Multiple Displays Topic is solved
ken536
Multiple Displays
Post by ken536 »
Hey there,
I'm currently making my own RGB Display Pixel boards. With multiple boards i'm able to make a huge LED display.
My boards currently hold 10 RGB LEDS like this:
Code: Select all
RGB   RGB   RGB   RGB   RGB
RGB   RGB   RGB   RGB   RGB
Each led had 3 adresses for RGB values.
Now freestyler is problably able to drive just one of these display's with LEDtrix. But how can I use multiple display's (and even on other DMX universes?!)
dmxlighting
FreeStyler Version: beta
Re: Multiple Displays
Post by dmxlighting »
not really sure what you are asking here ?
I think he likes to Control More then one Ledmatrix with just one Time freestyler.
But thats not possible you can only Control ONE led matrix at the time with Freestyler.
And if you like to have more Universes/Led matrix you need a Second DMX device and a Second Pc.
/Spirit
ken536
Post by ken536 »
Yes, thats what i mean.
Hmm. There will problaby be like 50 displays, so freestyler cant help me with this. Anyone a idea for
THE software i need for my application?
Thanks already!
ken536
Post by ken536 »
no one with software I could use best?
oke your idea is to Use Multiple SMALL RGB boards to Create ONE BIG RGB board?
Or to just use all the 50 small boards, seperate from Eachother?
Owww after some calculations, you need 1500 DMX channels, so 3 Universes.
the only Software i can Think of is Avolight Pearl 2010 With TITAN Mode i'm not sure which verion. but with the latest update they made a Pixelmapper. and that desk got 4 Universes, the only bad thing about it that its a Desk from around the 10.000 Euro.
Return to “Suntrix & LedTrix plugin”
