touchscreen2 all windows
DELighting
Post by DELighting »
I'm using a laptop with a large 23" touchscreen external monitor with the touch2 interface. The problem I'm having is that I would like my moving head units (Chauvet Q-spot 260) to have the "all windows" (gobo, color, macro, pan/tilt..etc...) over on the external monitor with the touch2 interface. When I drag the windows over they will go onto the second monitor, but will be behind the touch2 screen. I've had it set up in the past, but did the new 3.4.6 version change things a bit? I can't find how to have the gobo or color windows stay ontop of the touch2 interface on the second monitor.
DELighting
Re: touchscreen2 all windows
I downgraded t0 version to 3.3.9 and it works just fine. Something must have gotten changed in the newer version of the software to not allow the gobo and color windows to move over to the second monitor but to have them sit on top of the touch2 interface. They did move over to the second monitor, but always stayed behind the touch2 interface, making it useless.
Just posted a photo of it on the Freestyler facebook page for you to see that it did work in version 3.3.9
