Hi
I have a problem where i have selected my fixtures in 3d easy view that were already installed when i installed freestyler but my fixtures are scanners and the fixture files on easy view are brining up moving heads. Is there a way to change the fixture type or would i have to make a new fixture file for easy view and how do i do this?
Thanks very much merry christmas to you all.
Kelv
Wrong fixture type Topic is solved
- dmxlighting
- FreeStyler Version: beta
Re: Wrong fixture type
EV has it's own fixture creator which is very different to the FS fixture creator.
So you can make anything you want (within reason!) or edit existing profiles which are normally wrong or incomplete to begin with!
EV's fixture creator is not that easy to use but is worth spending a little time learning about. Plus the is specific forum somewhere on the EV website which may help.
- Uriahdemon
- FreeStyler Version: 3.5.5
- I Use FreeStyler for: Band
Hi, is the EV fixture creator within Sunlite Suite 2.... that is the only software i can see to download on their site...??
Mac
www.mclite.co.uk
www.mclite.co.uk
- Spirit
- FreeStyler Version: 3.5.9
you can find the Fixture creator for EV in the freestyler directory as SCANLIB
